RSE
September 30, 2022, 9:53am
1
I am using Capella 6.0 and I want to add an image into the description of an operational capability.
I have imported an image into my Capella workspace.
From there I tried to add the image via the add image button in the description, but sadly it will not add my image.
Has someone a solution for that?
Thanks in advance
Any error? What is happeing? Can you create links in your description?
RSE
September 30, 2022, 2:40pm
3
Hello Stephane,
Thank you for reply!
I do not know if one of these errors are relevant:
I can create these links:
I do not know if this is the right way.
Do I need to change some settings in Capella or something?
Works on my end - how did you import the image in your project?
RSE
October 2, 2022, 7:37pm
5
Via File-> Import->General-> File system
So once imported, you can see the image in your project but cannot add it into the description of a model element? Very strange…
RSE
October 2, 2022, 7:57pm
7
I can also not add the default images that are already in the img folder. I can select them and add, but nothing happens.
RSE
October 2, 2022, 8:32pm
9
Sadly that does not work for me.
I am using Capella 6.0 on Windows 11.
First time I hear of this problem.
What we’ve seen in the past is people unable to create links. In that case, the solution is here: Unable to generate html hyperlink in a Description Item with Cap. 5.2
Maybe you could try it to see if it works…
RSE
October 3, 2022, 7:20am
11
Oke thank you, I will try that.
RSE
October 3, 2022, 7:25am
12
This worked for me! Thank you very much.
Well, I am glad it worked, goot to know!
