Unable to generate html hyperlink in a Description Item with Cap. 5.2
I can’t generate anymore an hyperlink in a description item with Capella 5.2
But I succeed with the older Capella 5.0 version:
Do you know this issue?
thanks
dvd
This usually solve the issue:
  • close Capella
  • Go in the folder where you installed Capella
  • then go under\plugins\org.eclipse.nebula.widgets.richtext_1.2.0.201711021145\org\eclipse\nebula\widgets\richtext\resources\
  • right-click on the file template.html and display its properties
  • select the “unblock” tick box at the bottom of the popup and click ok (see image below)
  • Launch Capella
Stephane Lacrampe
Obeo Canada
Indeed, it is the solution
thanks
dvd
hello in version 6.1, the workaround does not work.
The path has changed a little: C:\Program Files\Capella 6\capella\plugins\org.eclipse.nebula.widgets.richtext_1.3.0.201912241810\org\eclipse\nebula\widgets\richtext\resources
  • Changing HTML file ownership has no effect
  • Do you have another solution?
    THANKS
Oups.
the bypass works perfectly, you must of course restart Capella
