Hello All,
Hope you are doing well !
I am new to Capella (using version 7.0.0), exploring ARCADIA to fit into my organisation’s MBSE framework.
I need guidance on resolving few tool usage queries which I am unable to resolve on my own. I went through few videos and user guides, however I could not find answer to the below ones.
Request to support me in resolving these queries.
If we edit a Function name or Functional exchange name in a phase, how do we reflect this update in the next or previous phases ?
Ex: In System analysis phase, I have defined a system function (SF) ‘Compute demand clutch position’ and one of the functional exchange input name for this SF is ‘clutch position’. The functional transition for this SF has already made to Logical Architecture phase. The function ‘Compute demand clutch position’ is seen as Logical Function (LF) in Logical Architecture phase. After further analysis, I decide to change the name of function to ‘Compute and Monitor clutch position’ and change functional exchange name to ‘current clutch position’ in System analysis phase.
Now, how do I transition these changes to Logical architecture phase ? When I used Functional transition on the modified SF, I see no updates available in the Functional transition window (refer attachment). Is it possible to please advise on how to transition the modified names to other phases ? All I am doing at present is searching the changes in all phases and editing manually.
How to revert back the hidden elements of Architecture Diagram (PAB) in Diagram editor ? For example, I select a node PC in Diagram editor and hide it using Ctrl+H or ‘Hide Element’ in the selection. Later,I realise that I need that node PC to be visible. if I wish to bring it back I do not see any option in the selection. There is a button called ‘Show element’, however if I click that button, I see no changes.
- In Architecture Diagram (PAB) how to change the line width of Physical links ? I see options to change, however they are not active.
- Is there an option to see the traceability of an element end to end. For ex. a Physical Function in Physical Architecture mapped till a Mission in System Analysis phase in one view ? As of now I believe the traceability is restricted to phase-wise.
Cheers !
