I have a doubt, is it possible to create a Library to share all the components of a model (project) to another model? I have created some NodePC and the connections between them. Also I have applied properties using the PVMT. I want to replicate the components to other projects, as the components are the same ones, but there is not any guide line to do so. Is it possible to do?
If you need the sets of components you will copy to be synchronized between your two models (I mean, so that, if you edit them somewhere, they would automatically be updated accordingly in the other models), then I think a good way of doing it would be REC/RPL.
You can see more about REC/RPL in the Capella help contents (Help/Help Contents/Capella Guide/User Manual/Replicable Elements).
Then, in the other project, i try to do the RPL, but it does not have the properties that I have given to the previous component in the first project. Do you know what is happening?
The problem is that does not allow to continue. I try to click on the OK button but nothing happens, does not execute the referencing action. Do you know what is happening?
