I would like to add an image in an e.g. Constraint, Logical Component, Logical Actor, …
In this Post it was described, how to achieve this, however it somehow doesn’t work for me (and I’m pretty certain that I overlooked something).
I tried the following steps
1.) Create e.g. Constraint
2.) Double Click and Navigate to Description
3.) Add Image (see Screenshot)
4.) No Image appears in Editor.
Thank you for your answers!
This is the image of the Description Property of the Constraint
Do you want that the image of the constraint ‘Test’ contains the picture you imported ?
For that, you need to click on the constraint and select ‘set style to workspace image’ (in the bar above), then choose a picture from your workspace.
Otherwise, picture in description is only displayed in description.
ok so to do this, you should not go to the description tab.
In your diagram, select your constraint, and then in the toolbar of the diagram, select the image icon.
Hello I tried applying this solution to add an image and its only letting me add images already in Capella which is just the element icons. I’ve tried adding an image to the file location, but its not showing. Is there something else I should be trying
Yes, once you have added an image in the file location, you should go back to your Capella project explorer, right-click on your project, and select “refresh”. Your image should then appear in your project and you can then insert it into your diagrams.
Let me know if that works.
Hi, following your steps, adding pictures is possible. Thanks! I’m wondering if it’s also possible to use transparent pictures that still keep the color and the frame underneath. Is there some way to do that?
