I recently presented a Capella model to my group, and my colleagues had a hard time reading the labels.
A recent discussion pointed out that the font size is hard-coded into Capella.
Before I submit a feature request on Capella’s GitHub page I wanted to check if this changes to default font size are planned in a future release of Capella. Or alternatively, maybe there is a really good reason for leaving the font size fixed, so I might as well not pollute the issues list on GitHub.
As a workaround, and if I feel adventurous, I can just change the font size in the XML file itself
I am working on Windows 11 with 4K monitors and scaling set to 100%.
Capella Icon size as well as all the menus and fonts are difficult to work with.
I am using other Eclipse based IDE’s, one of which I found reference to a user post pointing to a solution that will allow scalling of most IDE elements, such as icons, menus…
Editing the “Capella.ini” and adding the following parameters help solve some of the issues.:
The layers which make up the object ( background shadow and gradient color forefront) are moving away of each other based on the magnification level.
Any way this can be fixed (workaround or bug fix)?
