When i am generating a html documentation using the XHTML addon with Capella 6, the text of the block is misaligned, see next pciture
The original looks like this
Furthermore after starting Capella 6 and pressing HTML dcoumentaiton generation the documentation is generated. If i try to do it a second time the following error message appears.
Dont know whats wrong here.
Best,
Michael
Update: The same thing happens if I export a diagram through the “export diagram as image” command
I am having this same issue and it seems that it never got resolved for @m.naderhirn. Is there a solution for this?
I am using capella 6.1 and the appropriate XHTML docgen version. I am running on Windows 10, if that matters.
Could be related to a screen definition issue - not sure. Are you able to share your model or a sub-part of it with the issue?
Good call, Stephane,
After some playing around I found that it has to do with the way eclipse handles screen resolutions above 1080p. This is resolved by setting my screen resolution to 1080p before opening Capella per this thread
That’s great to hear, that’s what I was suspecting while not being sure.
