Please find below the questions that I had no time to answer during the webinar, and the corresponding answers!
Are the improvements in integration of Models with requirements management tools?
Yes. Publication for Capella connects Capella models to the main ALM/requirements tools through OSLC: Siemens Polarion, IBM DOORS Next, Jira (Cloud and Data Center), Jama Connect and, experimentally, PTC Codebeamer, which we are bringing to the full traceability feature set. Additionally, we are continuously improving Publication for Capella
Is there advancements for model change management?
Several options exist today: model comparison/merge (Diff/Merge) in Capella, Git-based workflows, and Team for Capella for real-time collaboration with locks and history. Publication for Capella recently added the foundations for version control (history, baselines, previews) and will provide API access to object history. Further down the road, Capella for SysON will benefit from SysML v2’s textual syntax and standard API, which make diff, review and versioning much easier.
Can direct simulation in Capella be possible in next release?
Capella has no built-in execution engine, and none is planned for the next release (2026.11, focused on the platform upgrade). Simulation is handled through bridges: the new open-source Capella Simulink® Connector (state machines and functional chains), Siemens EDA VSE analysis packaged in System Modeling Workbench, and, through the Capella SysML v2 Bridge, the growing ecosystem of SysML v2 simulation and analysis tool s.
This SysML v2 library with ARCADIA in SysON looks great - Is it ready-to- use?
Thanks! Capella for SysON is open source, and you can try it now (), but it is still early-stage and not ready for production. A first MVP is targeted for mid-2027. Until then, Capella Desktop remains the recommended solution for operational projects. Feedback and early adopters are very welcome!
When is this AI capability planned for?
AI for Capella is available now: 2026.9 is the first commercial release, following early-access versions 2026.5 and 2026.7. It is an add-on for Capella Desktop. Watch the recording of our ‘Connect Capella to Your AI Ecosystem’ webinar (September 24) and contact Obeo for access or a t rial.
Does the Simulink connector allow for the transfer of Exchange Items and Behavioral Components as well as Functional Chains?
The connector exports, from Capella to Simulink®: functions and functional exchanges with their ports, functional chains, state machines (states, regions, transitions), and exchange items with their data types (classes, enumerations, numeric types, physical quantities), which become Simulink buses and data-dictionary entries. Behavioral components are not transferred as such. The behavior is carried by the functions allocated to them. It is a one-way, Capella-to-Simulink flow. Mapping documentation:
Can the ARCADIA library for V2 add on work with any OMG Compliant V2 tool or just SysON
The library is plain textual SysML v2 (.sysml files) built only on standard SysML v2/KerML constructs, and it is explicitly designed to be tool-agnostic. It should load in any SysML v2-compliant tool (Papyrus Web, Sirius-based tools and others), and interoperability is our first design priority. The Arcadia-specific graphical editors, however, are provided by Capella f or SysON.
Where do we find access to the tool showed right now Capella for SysON?
Capella for SysON is open source on GitHub. You can build it or run it locally with the provided Docker Compose setup. It is still at an early stage (MVP targeted for mid-2027). Feedback and use cases are very welcome. Contact Obeo if you would like a guided demo.
Great to see your vision finally comes to fruition Stephen. Curious to see if your MCP server can work on Capella headless, or we need Capella desktop app being opened always?
Thanks Anbarasu! Yes, headless operation is supported: the Capella desktop UI does not need to be open. This makes it possible to use it in automated or batch scenarios as well as interactively.
Does Simulink connector integrate Simulink agents?
Not directly. The connector is a model transformation from Capella to Simulink® and does not drive Simulink agents. That said, AI for Capella exposes Capella through an MCP server, and MathWorks also provides MCP-based tooling for MATLAB. An AI agent can therefore work with both tools in the same workflow.
Would also be possible to automate code generation directly for m Capella models?
Yes, there are several ways to do this: Capella Studio/Acceleo for custom generators, Python for Capella scripts, or AI for Capella, where an agent reads the model through MCP and generates code with the engineer in the loop. Code generation is usually done from the physical architecture and data model (interfaces, exchange items).
There will be any work on updating the VPMS add-on for more recent Capella versions? Thank you
A VPMS version exists for Capella 6.1. As explained on the forum (), there is currently no plan to release a version for Capella 7.x. The port is estimated at about 15 days of work and could be done if one or more organizations co-fund it. Contact Obeo if you are interested.
Would automated requirement management by LLM be possible?
Yes. With AI for Capella, an LLM can work on requirements in the model (via the Requirements Viewpoint): drafting and refining requirements, checking their quality, suggesting trace links to functions and components, and analyzing impact. Changes are proposed and traced, and the engineer stays in control.
Additionally, validations rules can be extended and customized for specialized model validation?
Yes. Capella’s validation relies on the Eclipse EMF Validation framework. You can add your own rules (constraints) in a custom plugin, for example with Capella Studio, and enable or disable rules per project. For lighter needs, Python for Capella can also script specific model checks.
In Capella 7.1.0, the semantic browser have better performance. Are my own contribution to the SB will also be accelerated, or shall I rework on their implementation ?
To my knowledge, no rework needed: your own Semantic Browser contributions benefit automatically from the performance improvement.
With this SysON implementation, does it mean that in the future The eclipse platform will be abandoned ? What is the roadmap ?
No. The Eclipse-based Capella Desktop is not being phased out. Obeo is increasing its investment in it: 3 to 4 releases per year, new committers, and a major Eclipse Platform upgrade (2023-03 to 2025-09) in the next release (2026.11). Capella for SysON is an additional, long-term path. Roadmap: open-source foundations in 2026, an MVP targeted for mid-2027, then broader Arcadia coverage and migration support. The Capella SysML v2 Bridge provides a progressive migration path.
Is there a planned release date for the AI capability?
Yes, it is available now: AI for Capella 2026.9 is the first commercial release. Contact Obeo for access or a trial.
This SysML v2 library in SysON looks great - Is it ready-to-use?
See the answer above: the library is open source and usable for experimentation now (), but it is still under active development and not yet production-ready.
What’s the level of integration and interoperability of Capella solution s with Eclipse model based tools?
Very high: Capella is itself built on Eclipse modeling technologies (EMF, Sirius, GMF). Its models are standard EMF models, so they can be read and processed by Eclipse tools such as Acceleo, M2Doc, model transformations and validation. Capella can also be extended with Capella Studio (Kitalpha viewpoints). On the web side, Capella for SysON is built on Sirius Web and SysON (Eclipse Foundation) and on the SysML v2 standard API.
Is it please possible to export a model into a common format documentation (word, pdf, …) ? Is there existing template ? Shared template … ? Thanks for your answer
Yes. M2Doc (open source) generates Word documents from Capella models using templates that you can customize. Sample Capella templates are available on the M2Doc GitHub repository/website. Templates can now also call Semantic Browser queries directly. Capella also has a built-in HTML export, and Publication for Capella provides web publishing of models.
What will happen with future local client Capella installation for data security reasons if your plans are going to a fully web based Capella in the future?
Capella Desktop remains fully supported and actively developed, as a local client, for the long term. For the web-based path, Capella for SysON is open source and can be self-hosted on your own infrastructure (on-premises or air-gapped), so your data never needs to leave your network. Using a cloud service will be an option, not a requirement.
