Hi all,
I am using the combination of PVMT and M2Doc to generate documentation including information from Properties. I defined with the PV Configuration a set of Properties named System.ICDExtenstion.
In the m2doc template I added the following field:
m:ce.appliedPropertyValueGroups->select(p | p.name = ‘System.ICDExtension’).eContents()->select(a | a.name = ‘Identifier’).value
During the documentation generation an error is reported. The validation output is the following:
m:ce <—EClassifier=ElementExtension is not registered in the current environment <—Feature name not found in EClass AbstractConstraint Feature name not found in EClass ModelElement Feature
Nevertheless the output document is properly generated.
Is there any way to avoid such behaviour?
