Video showing the bug: https://www.youtube.com/watch?v=anB0WfH97Wo
Any interaction with REC/RPL menu (opening the menu to create a REC, instanciate an RPL or update a RPL from REC) will trigger this bug, which makes capella all buggy (ui elements becoming invisible, Activity Explorer throwing “Failed to create the part’s controls”, etc). The video doesn’t show, but when trying to interact with a diagram view, an error window keep appearing and interrupting workflow if I try to work despite the errors in log console and buggy ui.
This is happening on multiple 6.x and 7.x freshly downloaded Capella Versions, and even in 1.4, running both on Bluefin-dx 40 (based on Fedora Silverblue) natively on my machine and on a fresh Ubuntu 24.04 install on a virtual machine.
Github issue somehow related but unresolved since 2023: REC/REPL seems to be broken · Issue #2660 · eclipse-capella/capella · GitHub
Session Data:
eclipse.buildId=unknown
java.version=23.0.2 AND also java.version=17.0.14 (the one that comes w ith the capella download) AND also java 8 when running capella 1.4
java.vendor=Homebrew
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
Compilation of some of the errors thrown: Hastebin
