Hi everyone,
I’m facing an issue while trying to update my m2doc template from version 2.0.3 to version 3.3.0; currently the error when I try the M2Doc generation with my template in Capella is “M2Doc version mismatch: template version is 2.0.3 and current M2Doc version is 3.3.0.Do you want to continue?” But the document generated is not correct. How can I resolve this problem?
I’m unsure about how to proceed. Any guidance or advice would be greatly appreciated
Hi Led,
M2Doc 2.0.3 is an old version, but I think you should be able to reuse the same template with M2Doc 3.3.0. The first thing is to update the version number using the template properties wizard.
Then you can validate the template to see if M2Doc is happy with it and fix any errors or warnings that can be present in the template.
If you still have some unwanted behaviors, you will need to change the template and most likely change some AQL expressions. To write and check the behavior of your AQL expression you can use the M2Doc interpreter view.
Maybe check if the most recent version compatible with your version of Capella, you can visit this page.
I hope that will help, let me know if you have more questions.
