Hi everybody,
I’ve just downloaded Capella 1.3.1 and Java 8 u221 without beeing able to run it because Java returned exit code = 1.
What should I do ?
Please correct the installation procedure at
https://wiki.polarsys.org/Capella/Installation_Guide#Capella _Installation. There is no -showsplash option in eclipse.ini file.
Cheers,
Francois
Hi Francois,
This error comes from a problem with your Java version or Java installation. Are you on windows?
Can you make sure the Java version you have is a 64 bits version and not a 32-bit version?
The ideal java version is 1.8.0_121_64b and can be downloaded from here:
https://www.oracle.com/technetwork/java/javase/downloads/jav a-archive-javase8-2177648.html
All the best,
Stephane LACRAMPE
Obeo
JRE I’ve got for Windows should be 32b.
Now it works.
Thank you Stephane,
Francois
