Hi everyone,
I’m working on a M2Doc template that will be used to generate automatically a requirement traceability file.
At a certain point in the document, I would like to have a requirement traceability table that links the requirements with the Capella elements that are allocated to them. Here is what I tried to do to achieve this:
But then something weird happens. Everything works great except for the “Name” section where I got an error in the generated file, which says : “Feature name not found in EClass CapellaElement”:
However, when I use the Sirius interpreter in Capella, it seems that it should normally work:
Does any of you have an explanation about this behaviour ?
On top of that, if someone has an idea about how to retrieve the type of element (e.g. “functional exchange” or “logical function”), I would also be glad to hear it.
Thanks !
Pierre
