However the comparison does not seem to work.
I know that TEXT1 here is 'ID", yet the comparison does not work.
Do this 2 functions not return a string, explaining why the comparisons are failing?
I tried to check these, but wasnât able to identify a solution: M2DocHTMLServices - M2Doc M2DocGenServices - M2Doc
Thanks.
Edit : I usually check for types on the Capella interpreter, however the M2DOC interpreter does not show the returned âtypeâ.
To manipulate such elements you will need to create a Java service. MElement should be converted to EObject to be used without services. The is a bug opened for this:
Interesting.
I am note quite familiar with creating java services, donât know the how/where/when. My coding experience is mainly Python and C++.
Thank you for your response
An example of implementation can be found in the Sirius integration plug-in see the class SiriusConfigurationProvider and the extension in the plugin .xml.
SiriusConfigurationProvider lead to an empty page.
A) In 2019, you said that you would create a service that returns the âelement of interestâ in Capella (here:https:// stackoverflow. com/questions/59457543/how-can-i-access-to-the-dannotation-eoi-of-a-diagram-elements-of-interest-with )
It this the one : (((((https:// www.m2doc. org/ref-doc/nightly/m2doc_service_semanticbrowserservices.html#orgpolarsyskitalphaemdemodelelementgetelementofinterestfordiagramâsequenceeobject)))))
B) I usually use the âselectionâ or âselection.eClass()â to obtain the class of an element in my model, however the âelement of interestâ is not something that can be selected. How was it possible to establish that âelement of interestâ is actually a DAnnotation?
Same question for all other elements of the model that are not clickable.
C) When tryign to add the service related to the element of interest manually, it was impossible., Whether i have written ( getElementsOfInterest()) in the research bar, or SemanticBrowserServices, or even the full link org.eclipse.sirius.viewpoint, DRepresentationDescriptor.getElementsOfInterest(), nothing would show under the research bar. Only when selecting âCapellaâ package that i got all the services shown below.
This begs the question, how to actually add a single service⊠without having to tick the capella package box.
As I said earlier, I am quite used to Python & C++, however I never had to code a Java service or anything similar, I would not know where to start it. Maybe the missing page/link in my question number 1, would help? Thatâs an example of a full service?
From my understanding, i am guessing that creating a service can be done through Capella Studio maybe (following a tutorial similar to this one? https:// www.youtube. com/watch?v=NWCyKsPfc2Y ) or with Capella, following a tutorial similar to this one? ( Add Menu · eclipse/capella Wiki · GitHub ) and configuring org.eclipse.ui.commands and org.eclipse.ui.menus, but both examples seems to be targeting the developpemnt of a full add-on, rather than a service. Is creating a service for M2DOC a much simpler task? I would have loved to be guided through the process, eventhough this might be out of the scope of document generation? I am not sure. Instead, maybe get hints/guides where to start actually.
2.A) Yes I think it should return the same objects.
2.B) I had to look at the code of Capella and the XMI .aird model to find how this information was stored. I made a copy of the model to use as reference then added an element of interest and compared the two files.
2.C) You need to search for SemanticBrowserServices, but if you donât have the class in your workspace nor you template is inside a plug-in project that depend on org.obeonetwork.capella.m2doc.aql.queries, you will not be able to import it. You can edit the custom properties with MS Word and set:
Using an IServicesConfigurator is not mandatory to create a service. But you will need to be familliar with plug-in development and build. You can have a look at the Capella extensions on github to see how it is done. The build is done using maven and run using github action.
The viewpoint generates plug-ins but not what you will need here. But yes the Plug-in development perspective and plug-in project will be needed. A good starting point can be found here. And yes you should be able to do all this with the Capella studio.
I made a service Java in Capella Studio correctly, I was able to call it using one of the aql fields (service:MyFunction()). Now to transfert this java service into M2DOC template I believe that, in the case of no custom constructor ( Reference Documentation - M2Doc), then I need to do it through Template wizard ( Reference Documentation - M2Doc). Question: How am I supposed to transfert a function I made within a viewpoint in Capella studio to the menu of âEdit Template Propertiesâ and add it to the services run by my template? Am I supposed to âpackâ the function into some file or somethingâŠI donât see how that works. Reminder: The java service I made was defined within a âjava extensionâ:
Your service should be a Java Method into a class. This method should at least have one parameter. You can then import it with the template properties wizard. You will probably need to have the project containing your service class in your workspace. Then you can start typing the name of your class and it should show up in the dialog.
Then you will be able to use it like this in your template:
myObject.myService()
If you have more than one parameters:
myObject.myService(param2, parma3, ...)
Yes the plug-in containing the service must be installed if you want to use it outside your development environment. In your development environment it should be accessible if the class is compiled without error.
Very interesting, indeed the project containing the service class open in the workspace made it possible to add the java service. It went smooth! Perfect.
Question: isnât there a simpler way to pack the function? I will always have to ask an M2DOC user to âopenâ a workspace containing my JS?
To be honest with you I thought I had to add the name of the function (NEW6()) in the template properties wizard,
A Java Function
In reality it was the name of the J extension.
Thanks a lot! This was a mystery for me for a long time.
The first function takes a âCapabilityâ as a parameter and the second function takes âCapellaElementâ, I added the JS with âedit Template propertiesâ.
And the JS shows no âerrorâ.
Why would my item âUCDâ here, not accept/recognize my functions?
For distributing the template and the service you will need to include them to your update site. The service is a simple Java class that can be included in an plug-in. You can also add the template to this plug-in and declare the following extension point in your plugin.xml file. Then you can create a .genconf file and select it by using the browse registry button, you can also import it in your workspace for modifications see the link above.
For the Java service not being resolved, You need to have the metamodel declaring used EClass referenced in your template. Use the template properties wizard and check/add needed nsURIs. Your method also need to be public and should look somethink like this:
public Test1(Capalility capability) {
Note: naming convention from Java the service should not start with a capital letter.
and the value of the UCD variable should be an instance of Capability or one of it sub types. Otherwise AQL will not resolve the service since it signature doesnât match.
Well I thought I had only to add the JS with the TPWizard?
In any case, when i go the nsURIs tab, and I filter by âname of my classâ, âname of my functionâ or âname of my extensionâ I see no new available nsURI to add?
Change the version number to fit your version of Capella.
If you look in the Java package org.polarsys.capella.core.data.capellacore you will see a class CapellacorePackage the EPackage (or metamodel) for this part of Capella and it declare the nsURI you need to use.
It seems like M2Doc is able to load the Class with your services so maybe it has not been compiled since you added the last two services. Can you check if you have enable the automatic build:
I actually made sure any change in the JSâs is take, in account by Capella (thus by M2DOC?),
Right now I am just having the workspace of my JS open at the same time as my Capella projects (like you described the other time)
So I found out that, any change in the JS, can only be effective when you ârestartâ Capella. Not a big deal, that works for me. I also made sure to create everytime new functions to test them and to see if the new class is well incorporated, it seems so.
Thatâs strange because the class is loaded each time a generation is launched. On the M2Doc interperter view there is a refresh button to reload the template context so this kind of change can be taken into account.
Maybe you have the service in one workspace and start a runtime with the M2Doc template ? In this case a restart is needed unless you start your runtime in debug and the code might be hot swapped.
This time the new return value has been updated (notice the extra â3â character).
__
Maybe it has something to do with the fact i have an error, thus making M2DOC somehow reload older version of services somehow to be faster or something?
Or maybe because I am using 3.1.0? Idk.
I am not sure what you mean by âa runtime with M2DOC templateâ (If you are thinking about a runtime by CS then no)
Here is my configuration:
Capella
=> workspace1
=> A capella project, is already open, which is located inside workspace1.
=> I also open: plugin items containing my JS from âanother workspaceâ indeed (workspace2) (it stays open when I restart Capella even if my workspace is âworkspace1â).
The Capella workspace is âworkspace1â, and the JS come from from workspace2 indeed, the projects containing the JS are just âopenedâ.
To resolve my issue, I tried to restart Capella Studio (where I have my JS) AND capella everytime I could. Yet It did not seem to get rid of the
Invalid query statement: Couldn't find the 'test2(EClassifier=Capability)' service
Bring my services, by just opening the plugins located in my CS.
Very possible!
Indeed the changes I made were in CS, at the same time I had opened it in Capella and both were running.
Capella is such a machine, letâs agree.
__
I will try to copy paste my plugins inside the Capella workspace and see how it goes,
I could also compile those (with the Template) into an update site like you described, will keep you updated.
You are using the Capella Studio ? because in Capella PDE tools are not installed by default I think (or might need the developer capability to be selected).
