Hi I’m using capella 1.4.2 and M2Doc 3.2.0 and I encountered weird behaviour for the function isRepresentationDescriptionName().
Most of the time it worked completely fine in my model and document but after I tried to use it to export LABs something weird happened. If I use self.containedLogicalArchitectures.ownedLogicalComponentPkg.isRepresentationDescriptionName('Logical Architecture Blank')
to check for existing LABs I get an error and the validation file shows The predicate never evaluates to a boolean type ([Sequence(boolean)])
I interpret this as the function returning a Sequence(boolean) instead of a boolean (which should not happen according to documentation). Now, this problem can be solved by adding ->first() to extract the boolean from the Sequence. However, the error is thrown for all subsequent uses of isRepresentationDescriptionName() regardless of diagram types or usages.
If I do not check for LABs, everything works. If I use the code block, everything AFTER it throws the same Sequence(boolean) error. Currently, I “bypass” the issue in my model by not checking if the diagram exists. I just directly loop the representationByDescriptionName() for the corresponding diagram type…
Below I attached the code I’m using in a minimal test case to reproduce the problem. Uses 1 logical function, one LAB and one LFBD.
// Works fine
m:for LF | self.containedLogicalArchitectures.containedLogicalFunctionPkg.ownedLogicalFunctions
m:LF.name
m:if LF.isRepresentationDescriptionName('Logical Function Breakdown')
m:for rep | LF.representationByDescriptionName('Logical Function Breakdown')
m:rep.name
m:endfor
m:endif
m:endfor
// Introduces problem
m:if self.containedLogicalArchitectures.ownedLogicalComponentPkg.isRepresentationDescriptionName('Logical Architecture Blank')
m:for rep | self.containedLogicalArchitectures.ownedLogicalComponentPkg.representationByDescriptionName('Logical Architecture Blank')
m:rep.name
m:endfor
m:endif
// Does not work anymore (but works if I delete the previous code block)
m:LF.name
m:rep.name
m:endfor
m:endif
m:endfor
Then AQL continue the evaluation it will collect every navigation result in a Collection. After the ```
isRepresentationDescriptionName() call you get a Collection of Boolean. And the condition of the if must be a Boolean (scalar). That the reason for your error message. Using the first service is not a good idea here, you probably want to know if there is at least one true value in the Collection:
...->exists(b | b)
The last block should still be working even if the second block fails. Do you have the corresponding error message ?
The message location is the third block, even if it doesnt appear in the second block (for example, by using your suggested ->exists(b | b) to check if there is at least one true value in the returned collection).
If I use your suggested solution, I do not get the error message for the third block but I find this unsatisfactory.
If we go to my original example, the code I use is basically the following. Running Block A also prints out the name of the one existing diagram, so I would expect it to still be there when Block A runs a second time.
Block A -> No error
Block B -> Error
Block A -> Error
If I now use either first() or exist() then I get
Block A -> No error
Block B -> No error
Block A -> Error
If I use your let solution (Block C) instead of Block A it works fine, proving that the list of representations is not empty (implicitly proven by Block A as well if we look into the generated document)
Block A -> No error
Block B -> No error
Block C -> No error
But if copy paste the first block at the bottom again the error re-appears
Block A -> No error
Block B -> No error
Block C -> No error
Block A -> Error
If I delete Block B it works fine
Block A -> No error
Block C -> No error
Block A -> No error
That was a lot of cases. Essentially, I’m happy with finding workarounds but the error I experience should not occur. Because I get the impression that calling isRepresentationDescriptionName() on a collection permanently changes its behaviour for all subsequent calls which is of course undesirable.
