So we have a physical architecture of a system built in physical domain level in Capella.
Let’s say we have a following model showing two nodes connected to each other via physical link and ports on either side.
We can easily transition the nodes to configuration items in PBS domain. Is there any way to also transition the ports to PBS domain?
Because not only we want to specify the actual configuration item of nodes in PBS domain, we also want to specify the “type of connector” that realizes the physical port in physical domain.
I think you cannot define “type of connector”, you can rename the ports though. Hope this helps!!
