I need to analyse the traceability of function from a view to other ( exemple : logical to physical).
I try the create Traceability Matrix, but the columns name is too large and so in Capella it’s not easy to use it, the export don’t resolve the problem since i’m obliged to make too frequently a new export.
So i’m asking if there is not a solution to show it directly in a diagram, i.e. to have with property value or something else the name of the realised function who appear near or in the function.
Hi Amaury,
I remember this post from a few years ago that discussed a few ways to see realisation links: Cross-level realisation links in diagrams , which might help you.
From what you’re describing, I assume using title block might fit your need, as they should be able to display any kind of relationship.
Yes that seem to be a good response to my question. Thank for the help
Not sure that’s done the job finally. I don’t arrive to see well how to use title block to show realized functions, further more i’d like to show on the upper diagram which function is realized
I have to search in order to use the plugin (there is no build of it)
Yes, in that case, the best solution might be to take a look at the add-on.
Otherwise, if this does not work either, there is always the possibility for some custom development.
