I have a question about the system to subsystem transition (vertical transition to SA).
The generated submodel does not contain all generic packages by default (see candidate model in the merge).
If there is no capabilities linked to the sybsystem (no components or functions involved in any capability of the system), the capability package is not present in the candidate model. It is the same for others (data, actors, …)
Is it a normal working of the tool ?
It may be easier for subsystem generation if the generic packages were present by default in the candidate model and just have an additional SID after the transtion… (as it is the case for packages containing elements from the transition)
If we do copy all to the right, unused packages are automatically deleted from the resulting model.
Lisa Fumat
