- I have a model with logical components inside my System.
- I right click on this component to access
System to Subsystem menu. - I choose
Vertical SA. - I get a window to choose the targeted project and select options. I create a new project from this window.
- I click OK. And then… nothing ! The new project has correctly been created but the Diff/Merge window does not appear. The new project is empty, it does not contain items from the original System.
While doing this, I got the attached error logs.
I precise that my Diff/Merge works correctly while using Git. - Capella: v1.2
- System to Subsystem: v1.2.0
Thank you for your help.
