Hello everyone,
I’m trying to get the physical ports of a nodePC using the get_contained_physical_ports() method, which I found on a sample script which I am able to run ; but it doesn’t seem to work on my script with a nodePC that I fetch using the following command which I found in an other sample script :
elem = CapellaElement(CapellaPlatform.getFirstSelectedElement())
To launch my script, I right click on the nodePC in the explorer and I am able to see that it has been correctly fetched, for example elem.get_name() returns the actual name of the nodePC I clicked on to launch the script. However some specific methods such as the one to get the physical ports returns the following error when used on my fetched elem:
‘CapellaElement’ has no attribute ‘get_contained_physical_ports’
I assume this is either because the method is defined for a nodePC whereas my fetched element is of type CapellaElement or because I’m tryin to use java methods on a python object (or conversely). I tried to use the get_java_object method and to cast my elem to a NodePC with no success, it seems I am hitting a dead end. Basically, how can I convert my fetched elem to its actual type to use the methods I want on it ?
As you may see, I am a Python4capella newbie with not that much Java experience so I feel like I’m not seeing the simple fix for this somehow.
If someone knows what I’m doing wrong, and how I can realize it, your help would be much appreciated!
Best,
Theo LM
