All,
I have made the mistake of creating a Physical Architecture Blank from the “Create a new Physical Architecture Diagram” in the Activity Browser.
In reality I should have selected that component in one of the Physical Component Breakdown (PCBD) diagrams and right clicked and selected New > Physical Architecture Blank.
Is there a way to retrospectively allocate the PAB to the right Node Component in the properties or semantic editor so that I don’t have to recreate the entire diagram again as this will take a considerable amount of time.
KR,
JFAvi8
I just discovered that you can drag and drop diagrams into the appropriate area and the relationship is created successfully!
So I was able to drag my blank PAB diagram from the top level and drop it into the correct physical node component.
JFAvi8
Another option (less efficient than the one you found) would have been to recreate a diagram where you initially wanted, and then copy and paste the layout from your other diagram on it.
Thanks Stephane for your response!
Unfortunately I had put tens of hours into this particular diagram, and wasn’t sure whether a copy and paste of the layout would be successful…next time it happens I’ll be sure to give it a go!
Thanks again.
