When using the Validate Diagram (thought it would present the same way as Validate Model…), the warning messages appear as yellow warning icons on the relevant exchanges and functions.
I tried hiding them through the hide/show button, but with no luck.
Does anyone know how to remove/hide these yellow warning icons from my SDFB?
I don’t think you can. Did you check sirius preferences? Note that ‘validate diagram’ isn’t very well integrated with capella, because errors won’t show in the information view, but in the eclipse problems view, which doesn’t have support to navigate to model elements from validation results etc. To remove the icons from the diagram, you must delete the markers in the problems view.
You can remove all validation icons in diagram from the ‘information’ view, by clicking on the ‘clear view contents’ icon
That worked, thank you Felix!
