Hi!
I was trying to exploit Python4Capella to set some attributes owned by requirements in my model, the script that I wrote is something like this:
if False:
if False:
if False:
# include needed for the PVMT API
if False:
# change this path to execute the script on your model (here is the IFE sample).
# comment it if you want to use the "Run configuration" instead
aird_path = '/TMS_test_5/TMS_test_5.aird'
model = CapellaModel()
model.open(aird_path)
for req in se.get_all_contents_by_type(Requirement):
if str(req.get_id())=='1':
if req.get_java_object().getOwnedAttributes() != None:
for att in req.get_java_object().getOwnedAttributes():
if str(att.getDefinition().getReqIFLongName())=='Value':
req.set_attribute(att.getDefinition().getReqIFLongName(),100)
Checking the requirement.py in the simplified_api on my device it turns out that the “set_attribute” function for requirements exists but it just raises an error:
def set_attribute(self, attributeName, value):
status: KO
raise AttributeError("TODO")
It’s this issue being solved or there is another way to do that?
Thank you
