Setting property values with Python4capella
I created a property value named “mass” with PVMT, now I am trying to set its value for the logical component “TMS for electrical drive train” but using the P4C tool, I know that with “PVMT.get_p_v_value(lc, pvName)” I can get that value but it seems that a function with which I can do for instance
PVMT.set_p_v_value(lc,pvName)=float(variable)
doesn’t exist.
Is there a way to do that?
Here you can see the model and the property
Considering mass, is there an easier way to do this but with the basic mass viewpoint? (So addressing the value to the mass description in the physical level?
You can create different types of property value:
pv = PropertyValue(None, “StringPropertyValue”)
Is the default value but you can use: “BooleanPropertyValue”, “EnumerationPropertyValue”, “FloatPropertyValue”, “IntegerPropertyValue”, or “StringPropertyValue”.
In your case:
pv = PropertyValue(None, “FloatPropertyValue”)
pv.set_value(3.14)
Then you can add the property value you will need to get its property value group and then use:
pvg.get_owned_property_values().add(pv)
pvg.get_applied_property_values().add(pv)
Thank you,
And how do I set the value of a Property value already created with the PVMT editor?
Let’s say that once I created the “mass” Property I apply it to an element through the + button in the element properties, but then I want to set or change its value through a python for capella script, is there a way to do that?
Yes you are right this API is a bit confusing… I think the API should return the PropertyValue itself instead of its value. This way we could modify it.
You can try or start with:
    @staticmethod
    def set_p_v_value(elem, PVName, value):
        for group in elem.get_java_object().getOwnedPropertyValueGroups():
            for pv in group.getOwnedPropertyValues():
                if PVName == pv.getName():
                    pv.setValue(value)
                    return
This has some limitations:
  • it will only work if the property value exists
  • it will not work for enum property value
I opened a new issue:
I already tried that but get_p_v() takes just 1 argument and not 2 so pvName connot be specified, furthermore get_p_v() gives a list as output and so no value could be addressed to that list
Also trying to create a new property value from P4C as you showed and applying it to a logical component in this way:
for lc in allLC:
     if lc.get_name() == 'TMS for Electrical drive train':
        pv = PropertyValue(None, 'FloatPropertyValue')
        pv.set_value(3.14)
        lc.get_owned_property_values().add(pv)
        lc.get_applied_property_values().add(pv)
I obtain this error in the console
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
    @staticmethod
                    pv.setValue(value)
                    return
Yes that makes sense to me, I am now trying to implement that function but something is going wrong, using this script to modify just one Property Value for one Logical Element:
  if False:
  # include needed for the PVMT API
  if False:
  if False:
  if False:
  aird_path = '/TMS_test_5/TMS_test_5.aird'
  model = CapellaModel()
  model.open(aird_path)
  allLC = se.get_all_contents_by_type(LogicalComponent)
  allPVs = []
  print('start')
                  pv.setValue(value)
                  return
  for lc in allLC:
      for pvName in PVMT.get_p_v_names(lc):
          if pvName not in allPVs:
              allPVs.append(pvName)
  for lc in allLC:
          print(lc.get_name())
          for pvName in allPVs:
              if pvName=='Mass':
                  set_p_v_value(lc,str(pvName),int(500))
  print('end')
I am obtaining this error:
  File "workspace://test_1/test_5.py", line 58, in <module>
    Python object in all modules.
  File "workspace://test_1/test_5.py", line 43, in set_p_v_value
    _pyease_integer_types = (int,)
  File "C:\Users\Utente\Desktop\capella test 2\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\java_gateway.py", line 1321, in __call__
  File "C:\Users\Utente\Desktop\capella test 2\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\protocol.py", line 330, in get_return_value
    raise Py4JError(
py4j.protocol.Py4JError: An error occurred while calling o9470.setValue. Trace:
py4j.Py4JException: Method setValue([class java.lang.Integer]) does not exist
	at jdk.proxy12/jdk.proxy12.$Proxy25.executeScript(Unknown Source)
I honestly don’t know what is going wrong or where to look to fix it
Replacing in your function pv.setValue(value) with pv.setValue(float(value)) I get the same error that I reported yesterday (03/01)
		at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:349)
		at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:303)
		at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:285)
		at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:241)
		at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
		at org.polarsys.capella.core.data.capellacore.impl.FloatPropertyValueImpl.setValue(FloatPropertyValueImpl.java:108)
I was just searching for possible solutions and maybe this error is related
Yes you was not passing the right type.
To modify the Capella model you need to create a transaction:
#declare and open the Capella model
model.start_transaction()
try:
    # code modifying the Capella model
except:
    model.rollback_transaction()
    raise
else:
    model.commit_transaction()
You can find an example in this script for instance.
