At the logical level I created MSM diagrams for some of the logical components in the model, in these diagrams I placed the logical component states. In a similar way I have some nodePC on physical level and for some of them I created a MSM diagram.
How can I retrieve the states of the interested logical components and nodePCs with P4C? in my future work I woud like to retrieve also the region of each state.
As a workaround I was trying something like:
from pip._vendor.chardet.enums import MachineState
if False:
# include needed for the PVMT API
if False:
if False:
if False:
aird_path = '/Transition_test_2/Transition_test_2.aird'
model = CapellaModel()
model.open(aird_path)
allPC = se.get_all_contents_by_type(NodePC)
for pc in allPC:
print(pc.get_name())
states=pc.get_owned_state_machines()
for state in states:
print(state.get_name())
thanks for the help!
If you are using the element of interest you can define on a diagram, you can use the following method:
pc.get_element_of_interest_for_diagrams()
That returns the list of Diagram where this element is an element of interest.
You also have contextual element:
pc.get_contextual_element_for_diagrams()
if you navigate from the diagram:
myDiagram.get_elements_of_interest()
myDiagram.get_contextual_elements()
if the element is not on a reference above and just in the diagram, you can use:
myDiagram.get_represented_elements()
You can check this post for more details on the last method.
I am not using the element of interest but I am not sure about the terminology, anyway what I am trying to do is this:
I created a MSM diagram for “eMotors and eBoosters” nodePC
Then in the MSM diagram I need to retrieve the states, for instance “Cruise”, with its own region, in this case “56”
I tried now with this script
if False:
if False:
if False:
if False:
for pc in allPC:
if pc.get_name()=='eMotors and eBoosters':
diagrams=pc.get_element_of_interest_for_diagrams()
for diagram in diagrams:
elements=diagram.get_represented_elements()
for element in elements:
print(element.get_name())
But the script is not printing any element, I do not know how to get to the “Cruise” and “56” information knowing that is in the MSM diagram for “eMotors and eBoosters”
My idea was something like
for pc in allPC:
states=pc.get_owned_states()
if state.get_name()=='Cruise':
region=state.get_owned_region
value=float(region.get_value())
I think you should filter on PhysicalComponent:
allPC = se.get_all_contents_by_type(PhysicalComponent)
for pc in allPC:
NodePC is not a type of the Java Capella metamodel… I’m not sure how we can deal with this… Some methods directly returns NodePC but we can’t create a NodePC from a PhysicalComponent.
The problem is that for either PhysicalComponent or NodePC or behaviourPC the function “get_owned_states()” does not exist, and I was wondering if there is a way to create that kind of function.
Then I can use the “get_owned_regions” that is defined for “State” elements
You first need to get the StateMachine form the PhysicalComponent:
state_machine = pc.get_owned_state_machines()
Then you can get its list of Region:
regions = state_machine.get_owned_regions()
Then on each Region you can get the list of owned State:
states = region.get_owned_states()
At this step you can use your loop to select the 'Cruise' state.
