I am testing the Requirements VP add-on traceability features and have encountered some problems.
I would like to have visibility of traceability from Requirements to model elements. I’m not using ReqIF import but rather input requirements manually. So I created the structure below:
In order to test the traceability I created the traceability links below between the requirements and some model elements (functions and system). However, when I add the Requirement to the mass visualization view, nothing appears in the “allocating elements” and “allocated elements” columns. See below:
Even the traceability matrix (system functions to requirements) will not display any traceability.
The semantic browser does not show any traceability as well when I click the Requirement element:
The referenced elements will not show any traceability in the semantic browser as well:
If I inspect therequirement element, it does show the relations (called allocations):
What am I doing wrong here? Is it some problem with my installation? Tried this with both Capella 5.1.0 / Req VP 012.3 and with Capella 6.1.0 / Req VP 0.13.1.
Obs.: I did this test with a test reqIF file I had here and I had the same results.
