Is it possible to create multiple test cases per requirement? How can I model this in Capella?
There are no concepts in Capella for “Test Cases”. One paper (INCOSE 2019 best MBBSE paper award: https://mbse-capella.org/resources/pdf/IS_2019_Augmenting_Requirements_With_Models_Article.pdf ) discuss the topic.
There are different means to implement this in Capella. One could be to use an ALM to manage Test Cases and manage the traceability with Capella through Publication for Capella (commercial add-on). Another could be to extend Capella with a viewpoint to manage that. Or to use Capella existing constructs to model these Test Cases, the appropriate concept(s) would depend on what you want to model.
I hope this helps.
All the best,
Thank you i will try this
