Removing Relations from requirements
I need to setup a script to update allocation of requirements to components in accordance with imported ReqIF. I am working on Capella 7.0 with Python4Capella 1.3.0 and python 3.10.13.
I defined a relation named “Allocated to”
I would like to remove existing allocations
    for req in m.get_owned_requirements():
            logging.info("Reassigning requirement %s", req.get_attribute('IE PUID').get_value())
            rels = req.get_owned_relations()
            for rel in rels:
                if rel.get_relation_type()[0].get_long_name() == "Allocated to":
                    EObject.delete_e_object(rel)
when running the script I get a weird behaviour.
If there is only a relation or there are three or more, I get the following Java exception, while if two relations are associated to the requirement, only the first one is deleted.
java.util.ConcurrentModificationException
	at org.eclipse.emf.common.util.AbstractEList$EIterator.checkModCount(AbstractEList.java:751)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:699)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:685)
	at org.eclipse.python4capella.modules.JavaModule.iteratorNext(JavaModule.java:46)
	at jdk.internal.reflect.GeneratedMethodAccessor73.invoke(Unknown Source)
	at jdk.proxy16/jdk.proxy16.$Proxy42.executeScript(Unknown Source)
Solved!
The issue is related a concurrent access to an EMF list.
A frozen copy of the list is needed, and it is implemented by the following function:
def snapshot(e_list):
    copy = []
    for it in e_list:
        copy.append(it)
    return copy
Then the loop on the requirements is modified as follows:
        relsFrozen = snapshot(rels)
        for rel in relsFrozen:
                    rels.remove(rel)
I hope that it could help.
