Questions around Exchange Scenarios
For an Exchange Scenario in the systems analysis what is the best way to:
  1. Show that two functional exchanges from one actor to the system are associated with a single function within the system?
  2. How do I show that two functions within a system or actor should occur simultaneously?
1 - couple of options here:
  • use a constraint
  • display the same function on the lifeline
  • it could also be a naming convention on your FE label
  1. Use a “PAR” Combined Fragment (creating as many operands in it as you have parallel operations)
I hope this helps.
