I’m not familiar with Python4Capella and with Python language itself.
Does documents / training are available to teach how to start with Python4Capella?
Hi Fabien,
For the Python part you can start with any tutorial available only I guess:
- Python For Beginners | Python.org
- Getting Started with Python: A Complete Beginner's Guide (2026) | OpenPython
For the Python for Capella part, you can start by having a look at the project page and the installation section. After installation you will have a project with sample scripts. You can try to run some of them to get a starting point.
You can also have a look at the documentation, the documentation is also available in the Eclipse help menu. I also suggest you read the tips and tricks page for trouble shooting.
For more context on the Capella API you can check the metamodels (*.ecore files) and the corresponding Java code.
Later you might also have a look at EMF and Sirius.
And if you have some questions in the process feel free to ask them. I’ll be in holidays for a few week so responses might not be as fast as this one.
Hello Yvan,
I’m a bit late in thanking you for all that detailed information.
By following it closely, I was able to install the add-on and carry out some development work.
I also used the two files—filtering_header.py and filtering.py—that you provided here: Filtering Add-on and Python4Capella
Using them, I built three utilities:
- An utility to import a repository of
FilteringCriterionPkgandFilteringCriterionelements into a Filtering Model, and to initialize the Filtering Results (includingFilteringResultPkgandFilteringResult). - An utility to assign a
FilteringCriterionto a large number of modeled objects. - An utility to retrieve progress statuses (e.g.,
draft,reviewed_ok) and create a dynamicFilteringCriterion:
- Creation of
FilteringCriterionelements (e.g.,draft,reviewed_ok). - Assignment of the
FilteringCriterionto objects whose progress status matches that of theFilteringCriterion.
Best regards
Good to hear it worked out. On the third utility, one thing worth planning for is that an object’s progress status can change after the criterion has been assigned, so the stored link goes stale. A small reconciliation pass that walks the model and re-assigns based on current status (or removes assignments that no longer match) keeps the filtering results consistent. The alternative is to evaluate the criterion at query time in the filtering script rather than persisting it, which avoids the staleness but costs more per run. Which of the two fits your workflow better probably depends on how often statuses change.
