Python4Capella Docker image out now!
Hello /Scripting!
I’ve wanted to develop with Python4Capella for a long time (thank you @YvanLussaud for the great help), but when I started writing I realised there was no easy way of running scripts in a CI/CD environment. So, as a DevOps enjoyer myself, I set up a Docker image with:
  • Capella
  • Py4J
  • EASE
  • Python4Capella
  • also the RequirementsVP plugin as my test model uses it and others may too
…all nice and configured for easy use, with the In-Flight Entertainment sample model unpacked and all the Python4Capella sample scripts amended to run on an arbitrary target model.
Hope this helps someone :slight_smile:
Thank you very much for sharing your work. I’m sure this will help a lot of people.
Hello Chgio,
Thanks for sharing the Docker image.
On which version of Capella does your Docker image support?. Please let me know.
Hi Balamurali and thank you for your interest!
I versioned the Docker image to match the Capella version it uses: the current latest, 7.0.0-1, uses Capella 7.0.0.
Additionally, you can find the versions of all dependencies (including Capella and any add-ons) in the Release Notes.
Thanks again and happy docking!
Hi Chgio,
Ohh! We use the Capella version of 5.2.0. That’s why we see the Error on the log with “Wrong model version detected”
Docker command
docker run -v "C:\Users\OneDrive - Applied Materials\Desktop\workspace\Python4Capella":"/workspace/user/scripts/Python4Capella" -v "C:\Users\OneDrive - Applied Materials\Desktop\workspace\In-Flight Entertainment System":"/workspace/user/models/In-Flight Entertainment System" chgio/python4capella-docker:latest "/user/scripts/Python4Capella/sample_scripts/List_logical_components_in_console.py" "/user/models/In-Flight Entertainment System/In-Flight Entertainment System.aird"
!ENTRY org.eclipse.ease.lang.python 4 0 2024-10-24 10:43:52.641
!MESSAGE The method name "zip" from the module "__EASE_MOD_org_eclipse_ease_modules_platform_resources_ResourcesModule" can not be wrapped because it's name is reserved
!ENTRY org.eclipse.sirius.diagram 1 0 2024-10-24 10:44:27.899
!MESSAGE Migration done for "representation Change ID": all the representations changeId have been updated with the absolute time stamp (Ensure the session is saved to persist the migration effects. Please have a look at documentation about the project migration)
org.polarsys.capella.common.platform.sirius.ted.MetadataException: Wrong model version detected
Please have a look at documentation about project migration.
        at org.polarsys.capella.common.platform.sirius.ted.SiriusSessionFactory$SessionMetadataHelper.checkMetadata(SiriusSessionFactory.java:167)
        at org.polarsys.capella.common.platform.sirius.ted.SiriusSessionFactory.checkResource(SiriusSessionFactory.java:68)
        at org.eclipse.sirius.business.internal.session.SessionFactoryImpl.loadSessionModelResource(SessionFactoryImpl.java:166)
        at org.eclipse.sirius.business.internal.session.SessionFactoryImpl.createSession(SessionFactoryImpl.java:87)
        at org.eclipse.sirius.business.internal.session.SessionManagerImpl.getSession(SessionManagerImpl.java:271)
        at org.eclipse.python4capella.modules.SiriusModule.loadSiriusSession(SiriusModule.java:174)
        at jdk.proxy3/jdk.proxy3.$Proxy4.executeScript(Unknown Source)
        at org.eclipse.ease.lang.python.py4j.internal.Py4jScriptEngine.internalExecute(Py4jScriptEngine.java:248)
        at org.eclipse.ease.lang.python.py4j.internal.Py4jScriptEngine.execute(Py4jScriptEngine.java:235)
        at org.eclipse.ease.AbstractScriptEngine.inject(AbstractScriptEngine.java:190)
        at org.eclipse.ease.AbstractScriptEngine.run(AbstractScriptEngine.java:243)
!ENTRY org.eclipse.osgi 4 0 2024-10-24 10:44:48.440
!MESSAGE Application error
!STACK 1
java.lang.NullPointerException: Cannot invoke "org.eclipse.python4capella.commandline.Python4CapellaCommandLinePlugin$Implementation.log(Object)" because the return value of "org.eclipse.python4capella.commandline.Python4CapellaCommandLinePlugin.getPlugin()" is null
        at org.eclipse.python4capella.commandline.Python4CapellaCommandLine.runScript(Python4CapellaCommandLine.java:142)
        at org.eclipse.python4capella.commandline.Python4CapellaCommandLine.execute(Python4CapellaCommandLine.java:64)
        at org.polarsys.capella.core.commandline.core.CommandLineApp.launchApp(CommandLineApp.java:138)
        at org.polarsys.capella.core.commandline.core.CommandLineApp.start(CommandLineApp.java:72)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1440)
The Capella model you are opening is not in the same version as the Capella opening it. You can try to migrate your model before using it with the docker image. Or you can try to create/use a docker image with your version of Capella.
Thanks Yvan for pitching in!
Since there’s interest in older versions, I’ve prepared some additional Docker images using every major Capella release from 5.0.0 onwards.
@Balamurali if you still have your 5.2.0 model, could you please try pulling and using chgio/python4capella-docker:5.2.0-1 for your operations?
Hopefully this helps out.
Otherwise please do not hesitate to drop another update!
Thank you for providing docker images.
