When clicking on a PVMT property value and clicking somewhere else a null pointer exception is thrown. The gif below shows the problem. Is there anything I can do to prevent this error?
Versions:
- PVMT 50.5.1
- Capella 5.2.0.202111301257
Stacktrace:
!STACK 0
java.lang.NullPointerException: Cannot invoke "java.lang.Integer.intValue()" because "value" is null
at com.thalesgroup.vpd.property.adapter.vpd.impl.VPDPropertyIntegerAdapter.setValue(VPDPropertyIntegerAdapter.java:48)
at com.thalesgroup.vpd.property.adapter.vpd.impl.VPDPropertyIntegerAdapter.setValue(VPDPropertyIntegerAdapter.java:1)
at com.thalesgroup.vpd.property.adapter.vpd.impl.VPDAbstractPropertyAdapter.setValue(VPDAbstractPropertyAdapter.java:166)
at com.thalesgroup.vpd.property.adapter.capella.view.wrapper.PropertyViewWrapper.setValue(PropertyViewWrapper.java:111)
at com.thalesgroup.vpd.property.adapter.capella.view.VPDEditingSupport$1.doExecute(VPDEditingSupport.java:85)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:496)
at org.polarsys.capella.common.ef.internal.command.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:150)
at org.polarsys.capella.common.platform.sirius.ted.SemanticEditingDomainFactory$SemanticCommandStack.doExecute(SemanticEditingDomainFactory.java:277)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at com.thalesgroup.vpd.property.adapter.capella.view.VPDEditingSupport.setValue(VPDEditingSupport.java:64)
at org.eclipse.jface.viewers.EditingSupport.saveCellEditorValue(EditingSupport.java:116)
at org.eclipse.jface.viewers.ColumnViewerEditor.saveEditorValue(ColumnViewerEditor.java:446)
at org.eclipse.jface.viewers.ColumnViewerEditor.applyEditorValue(ColumnViewerEditor.java:312)
at org.eclipse.jface.viewers.ColumnViewerEditor$2.focusLost(ColumnViewerEditor.java:225)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:147)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1042)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2941)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1799)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:5163)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4774)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2681)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4931)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1228)
at org.eclipse.jface.window.Window.open(Window.java:795)
at org.eclipse.ui.internal.statushandlers.InternalDialog.open(InternalDialog.java:302)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:256)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:189)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:152)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:79)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(WorkbenchErrorHandler.java:52)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handle(IDEWorkbenchErrorHandler.java:106)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:34)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:218)
at org.eclipse.ui.internal.JFaceUtil$1.show(JFaceUtil.java:64)
at org.eclipse.jface.util.SafeRunnable.handleException(SafeRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:83)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:47)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(CellEditor.java:332)
at org.eclipse.jface.viewers.TextCellEditor.handleDefaultSelection(TextCellEditor.java:286)
at org.eclipse.jface.viewers.TextCellEditor.lambda$0(TextCellEditor.java:146)
at org.eclipse.swt.events.SelectionListener$2.widgetDefaultSelected(SelectionListener.java:102)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
