PVMT Installation Issue
Hello, I am trying to install PMVT as an update site but I am recieving the following messages, the installation can not be completed due to a missing requirement:
I searched for this feature to install it, however I could not find it.
Coud somebody support in that?
The PVMT CDO Feature is intended to be installed on the “Team for Capella” product.
The PVMT Contextualexplorer is used to contribute to a view “Contextual Explorer” that you can install aside the Semantic Browser. You can find it here:
eclipse-amalgam/amalgam
If you are using the opensource Capella, you can uncheck them when installing the update site (previous pane)
Thank you for the response.
From my side, I am still unable to see the domains in my property values window.
This is the domain I am trying to develop.
I am trying to customize the color and safety enumeration level of a logical component and the function. The following is the property window which shows nothing and the error log.
Thank you.
If i remember, i think this dialog displays the properties that are already applied to at least one element of the diagram no?
(and you need to use the “Properties Values” view to set them onto an element before)
Yes, the window you are referring to is in the background. I am clicking on the logical component to apply the property based on the defined domain and extensions. However, neither the domains nor the properties are displayed in that window.
