Hello, I am Using Siemens SMW. I have created requirements within Capella using Requirements Viewpoint and want to publish in Teamcenter. Is it possible? Is there any addon available. Please Suggest. Regards, Balamurali.
Hello Balamuri,
For any question related to SMW and the integration of Capella with Teamcenter, you should turn to the Siemens support.
However, to answer your question, the workflow you describe is not supported. You should create your requirement using the hosted Active Workspace and then bring this new requirement into your Capella model by drag & drop.
Thanks Laurent for the reply!
