is these any documentation that explain how to use property value to extend capella elements?
Thank you,
N.
Several sources:
- For plain Property Values, check this forum post :
https://polarsys.org/forums/index.php/mv/msg/318/1104/#msg_1 104 - For Property Values Management Tool (PVMT) add-on, check this webinar (
https://www.youtube.com/watch?v=ieVmw54YE94); once you download the add-on (
https://www.polarsys.org/capella/download.html), you will see a Help chapter dedicated to this add-on
Hope it helps
Thank you!
The webinard is very clear.
I couldn’t find the help chapter for PVMT in Capella. COuld you please be more specific?
Thanks,
N.
In Capella, you need to go to Help / Help Contents
You will see a dedicated section for PVMT (see capture enclosed)
Huh of corse!
thank you very much!
