Hello! If my project name contains Chinese, the document won’t be generated.
Can the m2doc plug-in support Chinese characters as project name in the future version?![]()
Do you have a stack trace in the error log view ?
The error log is empty.
But the generated file has reported an error, and there is no validation file.
Can you open an issue here with a small example to reproduce please ?
I don’t know when I will be able to look into that, but having a reproduction case will help.
Thanks for your reply. I’ve uploaded the model and the template. ![]()
Thank you. I don’t don’t think I will be able to look into this before the end of the year. I you need faster fix, you can contact Obeo for commercial support.
