Hey everyone, I’ve updated my capella installation from 5.1 to 5.2.0 and when I try and open my older projects, the system prompts me to migrate the projects. The problem is that the current instructions that I can’t find menu option for “Migrate” after right clicking the project. Any suggestions?
Maybe this will help: Problem migrating from Capella 1.4.0 to 5.2 - #6 by pdulth
Yep, that worked. Thanks.
BTW, I found that is you used the newest version of the filtering add-on it breaks the pop-up menu when you right click on a project. Using 1.6.0 results in only seeing a “New…” menu option when you right click.
Filtering 1.6.0 is for Capella 6.0: Release v1.6.0 · eclipse/capella-filtering · GitHub
Are you not on a Capella 5.2 ? If so then it is recommended to use the right version of the plugin Releases · eclipse/capella-filtering · GitHub. We cannot always ensure compatibility of newer versions of the Add-ons with older versions of Capella.
Arnaud
