using Capella 1.3.1 on Windows 10 I can’t see the hyperlinks I created in the Documentation pane for my project.
process is: Link/ Diagram Element / Browse & select (URL Display is Ok then)
URL Display test is there but no hyperlink selectable…
same for Add Image, nothing seems happening.
Other ‘strange’ features for Cut and Copy icons, not visible
Olivier
Can you check if there is a error at Capella startup or when you edit the description.
It may be due to a too long installation path.
Philippe
well done, I can use hyperlinks and images now !
and…the cut & copy icons missing looks just on purpose, when selecting something (text or image) they will appear …
I put Capella at root c:\ and I will always in the future do so and recommend the same to customers
thanks for your help,
Olivier
