I am trying to Import Requirements I have exported as ReqIF from Polarion before.
I use Capella 7.0 and Requirements Viewpoint 0.14.0.
I can select to ReqIF file and start the import.
The result in an error log
C
C
Capella breaks when ReqIF.ForeignID attribute values contain non-numerical characters, I’ve written a bit about it at Import/Export ReqIF - #16 by huvrhxlerukmgoymuc. This attribute usually contains requirement IDs in the authoring tool, so you’d have to make Polarion export these as numbers-only values or export the requirement IDs into a different attribute. If there’s no such setting, you could do a regex replace on the .reqif file before import.
