I had the same issue a couple week ago.
I think the mac OSX package is incomplete. I had to perform some tweak to manage launching it.
First, open the app package, under macOSX dir create an eclipse.ini file with the following content :
the path library for java vm should be different on your computer, look in your directory
/Library/Java/JavaVirtualMachines
The second thing to do is to add executable attribute to file
eclipse (in the same directory) : use chmod o+x eclipse
This should work afterwards.
Fabrice
Thanks a lot, it now works thanks to you tip.
Wael
Very useful! Thanks Fabrice.
