Hi all,
there is a problem in PVMT Capella 5, we can not modify a boolean property on Property Value view but just in Project Exlorer view
however it is possible to do so using Capella 1.4.2
Any solutions for that ?
Hi all,
I confirm I have the same issue with Capella 5.1.0 and PVMT 50.5.1
Also, I am having the following issue: changing the color of border nodes on physical components: nothing happens when I create a rule for it, although changing the background or label color works in the same context
I can file a bug if I am not the only one seeing this.
Hi, I have the same issue on my project migrated in capella 5.2 (border color configured with PVMT doesn’t change), this appears in PAB diagrams (OK in PCB diagrams).
Did you find a solution? Is this problem fixed in CAPELLA 6.x?
Thanks for your answers
