You can clone your diagram before adding the LC6 component ; by this way, when you will add LC6 component you will be able to copy/paste the internal LCx components layout of your current diagram.
Hope this helped you.
EDIT… while I was posting @SMonier also posted. The cloning of the diagram as suggested makes this process even easier than starting from a new blank diagram.
