I’ve recently been trying to work through a scripting task that requires me to know both the id of a CapellaElement (e.g. a PhysicalComponent) and the corresponding id/s for the part/s. Is there a way to get the id for the part using Python4Capella?
From a Component you can get its list of representing Part using the Java API:
parts = myComponent.get_java_object().getRepresentingParts()
Then you can get the id from the Java Object Part:
id = myPart.getId()
Thanks Yvan. That worked perfectly.
