Hi everyone,
I’m currently working on extending an existing Capella model by adding new Logical Functions. So far, I’ve successfully created these functions and linked them to higher-level functions. However, I’m having trouble allocating them to Logical Components.
I came across another post that explains how to allocate a function to a component in the System Analysis (SA) layer using the following code:
cfa = create_e_object("http://www.polarsys.org/capella/core/fa/" + capella_version(), "ComponentFunctionalAllocation");
cfa.setSourceElement(actor.get_java_object());
cfa.setTargetElement(sys_fct.get_java_object());
actor.get_java_object().getOwnedFunctionalAllocation().add(cfa);
I assume a similar approach can be used for the Logical Architecture (LA) layer, by changing the namespace to:
cfa = create_e_object("http://www.polarsys.org/capella/core/la/" + capella_version(), "<something>");
However, I’m not sure what to replace <something> with to correctly allocate a fuction to a component in LA. (ComponentFunctionalAllocation does not work)
Has anyone done this before or knows the correct element name to use in this context?
Any help would be greatly appreciated!
Thanks in advance!
