I installed Capella 1.4.2 yesterday to my Windows 10 and was working on a tutorial of Toy Catapult Project. And facing a problem.
On my [OCB] Operational Capabilities diagram, I clicked the Operational Capability on the palette and then clicked in the working area. But it won’t appear on the diagram while an Operational Capability entry is added to the “Operational Capabilities” folder in the Project Explorer.
Does anyone can help me solve this issue?
For the detailed log, please see below. Log file contents with my description about what I did.
Step 0: After launching Capella, I see those in the log file:
!SESSION 2020-12-09 15:28:37.748 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_271
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=ja_JP
!ENTRY org.eclipse.egit.core 1 0 2020-12-09 15:28:41.301
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.egit.ui 2 0 2020-12-09 15:28:51.092
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\iai'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
Step 1: After creating Operation Entries diagram, I see those in the log file:
!ENTRY org.eclipse.gmf.runtime.common.ui.action 2 6 2020-12-09 15:32:26.483
!MESSAGE C:\Program Files\Java\jre1.8.0_271\bin\awt.dll: Can't find dependent libraries
!STACK 0
!ENTRY org.eclipse.gmf.runtime.common.ui.action 2 6 2020-12-09 15:32:26.489
!MESSAGE Could not initialize class org.eclipse.gmf.runtime.diagram.ui.render.clipboard.AWTClipboardHelper
!STACK 0
!ENTRY org.eclipse.gmf.runtime.common.ui.action 2 6 2020-12-09 15:33:27.358
!STACK 0
!STACK 0
Step2: After creating Operation Capabilities diagram, I see those in the log file:
!ENTRY org.eclipse.gmf.runtime.common.ui.action 2 6 2020-12-09 15:35:03.821
!STACK 0
!ENTRY org.eclipse.gmf.runtime.common.ui.action 2 6 2020-12-09 15:35:03.828
!STACK 0
Step 3: After putting an Operational Capability entry, I see those in the log file:
!ENTRY org.eclipse.gmf.runtime.diagram.core 2 2 2020-12-09 15:36:24.788
!MESSAGE IRJS0005E Failed to create view org.eclipse.sirius.diagram.ui.internal.view.factories.DNodeViewFactory
!STACK 0
!ENTRY org.eclipse.ui 4 0 2020-12-09 15:36:24.867
!MESSAGE Unhandled event loop exception
!STACK 0
Also the below is the corresponding lines in Usage.log
2020-12-09 15:31:54,360;Capella;1.4.2.202010140908;Open+Session;ToyCatapult_3.aird;;
2020-12-09 15:31:56,004;Capella;1.4.2.202010140908;Open+Session;ToyCatapult_3.aird;OK;
2020-12-09 15:32:22,784;Capella;1.4.2.202010140908;Create+Representation;Operational+Entity+Breakdown;;ce822136-d7bf-4924-98ea-0010f4663426
2020-12-09 15:32:25,308;Capella;1.4.2.202010140908;Create+Representation;Operational+Entity+Breakdown;;ce822136-d7bf-4924-98ea-0010f4663426
2020-12-09 15:32:25,478;Capella;1.4.2.202010140908;Create+Representation;Operational+Entity+Breakdown;OK;ce822136-d7bf-4924-98ea-0010f4663426
2020-12-09 15:32:26,611;Capella;1.4.2.202010140908;Create+Representation;Operational+Entity+Breakdown;OK;ce822136-d7bf-4924-98ea-0010f4663426
2020-12-09 15:34:59,739;Capella;1.4.2.202010140908;Create+Representation;Operational+Capabilities+Blank;;684f7767-828a-4dee-a805-9fa45b0fa7d0
2020-12-09 15:35:03,506;Capella;1.4.2.202010140908;Create+Representation;Operational+Capabilities+Blank;;684f7767-828a-4dee-a805-9fa45b0fa7d0
2020-12-09 15:35:03,533;Capella;1.4.2.202010140908;Create+Representation;Operational+Capabilities+Blank;OK;684f7767-828a-4dee-a805-9fa45b0fa7d0
2020-12-09 15:35:03,901;Capella;1.4.2.202010140908;Create+Representation;Operational+Capabilities+Blank;OK;684f7767-828a-4dee-a805-9fa45b0fa7d0
