Hello~ I’m trying to get the allocated operational activities of an operational entity. However, the query works in interpreter, but the generated file doesn’t have any content.
Interpreter:(the activities can be acquired by typing aql: self.allocatedOperationalActivities)
template:
generated file:
model structure:
entity:
oab diagram:
Hi Beka, thank you for your reply!
- I haven’t wrote summary in my capella elements, but they can be generated successfully if I write them. In the In-flight management project, the operational acitivities and summary can be acquired successfully.
- My query sentences are accurate. I’ve tested them in other models like IFE system. But in this model, my queries fail to get the content, so I just want to check if you guys have met such problems before. I guess there are something wrong with this model specifically.
- No validation document is generated. There are no error messages.
Best regards
Qifan
Sometimes a perfectly fine query would work on a sample project but would not work on an actual project because of an unforseen missed configuration.
I think you should try to write in the summary something and see. I would also, nevertheless, try to insert words between my accurates query sentences and see if there is an issue non related to the queries somehow. That’s how I would do it.
Best regards
BeKa
