With some past experience with Papyrus, I started to use Capella for generating documentation.
I played a bit with the IFE example, the Sirius perspective, and the M2Doc interpreter.
Considering the SA template, I would to like in the operational capabilities, and I tried the following within a loop:
self.eAllContents (la::OperationalCapability) to retrieve the associated objects.
This ObjectType sounds to be wrong → invalid: invalid type literal
The EClass information neither provide my datatype (as it is @ a ECore level), and I also didn’t find the appropriate properties view for this.
Is there a link to the Sirius library documentation, or how do you usually proceed?
Thanks by advance,
Samuel
