OAB & OES Diagram Generation
Hello everyone,
"I’m using M2Doc 4.0.1 with Capella 7.0.1. I want to embed OAB (Operational Architecture Blank) and OES (Operational Entity Scenario) diagrams in my template.
What already works:
  • OEBD diagram: self.containedOperationalAnalysis.ownedEntityPkg.asImageByRepresentationDescriptionName('Operational Entity Breakdown')
  • OCB diagram: self.containedOperationalAnalysis.ownedAbstractCapabilityPkg.asImageByRepresentationDescriptionName('Operational Capabilities Blank')
What does not work:
  • OAB: The diagram is found with self.containedOperationalAnalysis.containedOperationalActivityPkg.eAllContents()->select(e | e.isRepresentationDescriptionName('Operational Architecture Blank')) returning true, but retrieving the image fails because eAllContents() without a type filter causes ‘EClassifier=ElementExtension is not registered’ errors. What is the correct element type that OAB diagrams are attached to?
  • OES: Same issue – the diagram exists on OperationalCapability elements but self.containedOperationalAnalysis.eAllContents(oa::OperationalCapability).asImageByRepresentationDescriptionName('Scenario') returns no image.
What is the correct AQL expression for both OAB and OES diagrams?"
Thank you!!
I found a solution.
{m:for sc | self.containedOperationalAnalysis.eAllContents(interaction::Scenario)} {m:sc.name}: {m:sc.availableRepresentations()} {m:endfor}
Helps you findig out the correct names.
You can also import *kitalpha* metamodels (nsURI) in your template using the template properties wizard.
