Hello
Don’t know if this is doable or not.
Let’s say I have the following EAttribute:
I found it impossible to obtain the value of this attribute from this attrbute:
- eInverse() does not work, I could get to the original object (its name happen to be “origin” here), I mean i used eInverse(class of origin), it would not work.
- the attributes of THIS attribute were of no help:
- eAllSuperTypes might not help.
Is there anyway to obtain the value of the attribute (here id would be (3a106ac6-2d73-4fd8-9e68-3ff583071791)), when you have the “EAttribute” as a starting point in your aql call.
I guess not?
__
My goal?
Is to obtain the value of all (eAllStructuralFeatures) without having to write the name of the attribute next to the element you are studying, if that makes sens?
In other words I want to find an aql call that gives you a Sequence containing this:
Object.eAllStructuralFeaturesOfCurrentObject.values
