I recently added this viewpoint for experimenting with configurations, but ran into an issue with a corruption(?) of the Diagram Editor Palette
Once I added the viewpoint via the dropin folder, I found that the Zoom (+) control button disappeared. Also the “Text” and “Note” objects disappeared from the Note pulldown menu (note: Link Note and Note Attachment remained undisturbed). I recovered from the issue by removing the viewpoint from the drop-ins folder to restore Capella back to prior status.
Questions:
- I researched with Capella for an ability to manually re-enabled these items to the Palette, but could find no method. For example, right click in the Palette bar area and selecting Customize did not provide a way to “turn on” the missing features. I then searched in Capella Preferences and so forth. Is there a way to re-enable the missing items with the viewpoint installed, maybe I just need some guidance to find the way?
- Assuming this issue is known for Capella 1.2.1 and VPMS 0.12.0, is there an updated version that fixes this issue? (I have vpms 0.12.0.20181121400 that I retrieved using the link provided in the YouTube video that covered this viewpoint).
- Since I’m still interested to work with this viewpoint, is there a published buglist available to review so I can understand if other issues would prevent me from adding the viewpoint into my Capella installation. We like the idea, but may not be possible to use if important Capella features are compromised.
Thanks,
Scott
